tom-galletti avatar image
tom-galletti asked
Generator start/stop wiring
Hey,
I'm trying to configure the auto-start/stop for my generator using a Cerbo GX.
The Generator starts with a (very common) 3-wire ATS plug. I've run a 12V +ve and -ve from a battery and spliced to my communication cable as directed here.
1628085605000.pngThe start/stop relay on the Cerbo is 3-wire (NC, NO, COM). Does anyone know how the ATS wiring and the Victron relay wiring marry up? I can't find any documentation online.
Cheers
Generatorauto gen start
tom-galletti answered ·
I've managed to answer this myself purely by chance, so will update here in case it helps anyone else:
on the ATS end:
1 -> live wire
2 -> neutral wire
3 -> earth wire
on the Victron end:
live -> NC
earth -> COM
neutral -> NO
Note - on my Hyundai, you must NOT run 12V through the neutral and live wires (despite what the ATS diagram says) or the gen won't start.
You must also make sure the ignition is set to OFF, or the gen won't start.
Hope this helps someone else.
nesswill avatar image
nesswill answered ·
Hi, would this work with my Genny
It's a DHY18KSEm controlled by a MRS10.
Thank you, Dave.
MultiPlus Generator FAQ
GX - Generator auto start/stop
Automatic Generator start/stop
 Hybrid Generators
Virtual switch - Generator start/stop
