Hello community,
So I'm trying to implement a system of two single-phase Quattros that can give me one two-phase output. I'd also be adding a bank of batteries to this system. This bank of batteries should only be used when the grid goes out. If within 15 minutes the grid is still out, I'd like a generator to start working and feed the loads. Is there any way to configure this kind of timing of a generator? If so, how's the wiring? Can you please refer me to a connections diagram?
I'll also be using a Color Control.
Is there a way for the generator to stop working after the grid is available again?
Thank you for your respones, have a nice day
