I'm looking to solve a general problem with a considerably low solar output from my 3 Solara DCsolar E680M48 170Wp (510Wp in total).
Currently they are wired in series, but all tests have been made also wiring them in parallel. From the modules there goes one 6mm2 wire (3m long) down to a circuit breaker. From the circuit breaker another 6m long 16mm2 wire to a junction box and from there about 1m long 6mm2 into the Smart MPPT 150/35 PV input. All connections have been checked numerous times, cables are checked as well as the circuit breaker for continuity. No significant voltage drop except for what to expect, especially when modules are wired in parallel. Checked all terminals and connections for temperature.
I also checked the modules for Voc and ISC in what I call perfect conditions for my location. 23.44V and 7.81A for all 3 modules, which are even a bit higher than the rated output. Measurement were taken with an ambient temperature of 24°C, cell temperature max. 46°C. Temp.coef. is -0.32% / C°.
However I only can get about 355W out of them when wired in parallel and 370W when wired in series. This is far less (26-27%) than what I would expect, even if I account for more voltage drop or an even worse temp.coef than advertised. Modules are perfectly aligned and tilted for my location.
When I cool the modules down with cold water, output increases, which makes up for temp.coef, but still missing around 100W.
The funny thing is that with low ambient temperatures like we had in March and April, I had no problem to get full output. But there seems to be a point in temperature where everything changes all of the sudden with nothing in between.
I'm not sure everything is still within limits, but it feels like it is not. I've been in contact with Solara and they say that with my Voc and ISC measurements everything is fine and they are out of the game.
Maybe there's someone out here who has an idea where or what to look for.
