Is there a reason the the manual says mount the MPPT 100/20 with the terminals at the bottom?
Another post on the community forum says.... 'Moving upside down is risky: it makes it easy for water to flow into the controller, destroying the controller and possibly putting PV voltage onto the battery output with it' and 'water will "wick" inside the plastic sheath, along the wire strands. Capillary action...'
In my installation the the PV cable runs for some length below the level of the controller and through a switch, so water is not going to get into the MPPT through the PV cable.
Is there another reason it can't be upside down?
