tronde avatar image
tronde asked
How can i measure/show the generated Solar-Energy from my Envertech EVT560 (3x) in the dashboard
Hi All,
my ESS has 3 Envertech EVT560 Grid tied solarinverter. (an also the Enverbridge Measuring device, but it´s not working so well)
How can I
a.) measure the generated solar power in the Venus GX (by external current sensor ?)
b.) I haven´t found a way to tell my system (Venus GX) about these Inverters, is there a way to implement them into the systen datawise ?
c.) Yes, I would like to see the generated Solar power displayed on the dashboard. Has anyone experience what I can to in this case ?
ESS
You will need to use an ET112 for each inverter (not sure if one ET340 will work)
https://www.victronenergy.com/accessories/energy-meter
