Can someone please interpret for me what the app is showing? It says solar voltage is 13.38V, I checked the voltage from the panels and it was at 36v. Also it is showing 0 current, and 0 watts, because a relay is 'open'? what is this relay ? I have the short wire between H & L so that is not the problem. It is very overcast out here, so the voltages from the panels are between 3v and 36v. The voltage under "Solar" is that the output voltage of the MPPT? or input from the panels?
