Smart Solar – 450/200 is connected about a Cerbo GX to the MG Master LV BMS (Lynx) via VE.CAN (Lithium Batteries).
The BMS and the smart solar are shown correctly into the Cerbo GX menu.
Into this menu, the BMS is listed as allow to charge.
The Smart Solar generally works, but when I select the Battery type LiFePo4, it has to be controlled by the BMS.
I got the Info: “BMS switched off” but it is on and the charger did not charge.
