This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
A Multiplus is designed to work with one input/output voltage only. You'd need to adapt the incoming AC voltage to your Multi and the rest of your AC system. You can use a 220 to 120 volt transformer (auto or isolated winding) to bring the 220 v South American power down to 120 volts.
An alternative is to use separate charger (Phoenix or Skyla) and inverter (Phoenix). Victron chargers operate on a wide range of input voltages and frequencies.
44 People are following this question.
