What does Max battery current limit mean in this text? Does the writer mean that there are units have max current from PV up to 100A
Mppts :example 100/15
The second number you will see on MPPT , typically the smaller number,
starting at 10 and going to 15 and 20 and 35 and 45,all the way up to 100 is the battery current limit.
This is the maximum battery DC current
you'll get out of the unit .This will be converted at excellent efficiency from the higher PV input voltage.
