I have the following setup : 1 x Multiplus 12/1600/70 and 6 AGM Deep Discharge Batteries connected in parallel.
This is going to be installed on a temporary construction site to power up the CCTV system.
During working hours the system will be powered from the site mains 220V generator charging the batteries.
So as I can understand the Multiplus has to be set up as a UPS system.
Do I need to change any settings with the Dip Switches (I don't have the USB interface) or it will work as is out of the box?
( I monitor the batteries voltage real time with a GSM safecurrent device(
