I have a bank of 6 AGMs each over 100 Ah. The bank is charged by x8 145W flexible panels. Each panel has a Bluesolar MPPT 75/15 with identical settings. Two of my MPPTs show 0 amps from solar, the voltage from solar looks fine (19v) and from batteries between 12v - 13v. Each MPPT has the same settings. And can see solar, and battery, volts and amps. I have checked the fuses.
