What wire sizes and fuses sizes should I use? I have 2 X 115w mono panels in series (24V) going into a Smartsolar 100/20 on one side of my boat. I have the same on the other side. The outputs form the two controllers are commoned in a junction box the goes the 12V, 420Ah battery bank. The cable run from the panels to the controllers is around 8m. The run from the controllers to the batteries is around 1m.
Panels to MPPT controller?
Controller to junction box?
Junction box to batteries?
Thanks... from a confused non-techie.
