I'd like to get a Multiplus 12/800/35 charger/inverter for my van conversion, which has a TN Power LFP12100 100Ah leisure battery.
However, after checking the manuals/videos/etc, it seems pretty clear that the Multiplus is not happy charging generic Li-ion batteries. I may be able to get it working if I get an MK3 adapter and try to set it up specifically, or I may not, and the MK3 seems to cost as much as an unbranded generic Li-ion charger anyway.
Question: is it likely that I can charge this battery using just the DIP switches? Is it likely that I can charge it by programming the Multiplus? Or should I just buy a separate charger and inverter? Thanks.
