VConnect App says when configuring Low SOC relay: "When the state-of-charge percentage is between the set and clear, the relay will be closed"
Great but it doesn't seem to be doing that. I want the relay to be closed whenever the SOC is between 30 an 80. ie. SOC > 30 and SOC < 80. Less than 30 or greater than 80 it should be open.
Does the SOC have to get down to the lower value before it will close and then only open when it gets to the higher value or can I have it do what it says it will do? If not is there a way using usb/vedirect cable to send simple commands to control the relay?
Thx
