Current settings shows the battery goes to 100% before the voltages are any way near what they should be.
Are the proposed settings correct if not looking for advice. Thanks in anticipation
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hi @ajfeather
It's very difficult to suggest anything without knowing more of your real issue. You say the SOC "goes to 100%" prematurely. Does it synchronize early, ie. with a clear jump to 100%? Or does it climb to it gradually, but too quickly?
If the latter, it may mean that the Charge Efficiency is set too high. If the former it will involve the Tail Current as well, not just V.
I've a hunch that your proposed changes are a step backwards, but there's not enough info to be sure. Maybe post a screenshot(s) of the BMV settings and try to define the issue a little more thoroughly.
The mppt settings should be made to suit the battery recommendations and conditions, not to experiment with the BMV.
50 People are following this question.
