I wonder if anyone has answers to the issue below.
This is an identical issue experienced by Louise which was posted on here; Multiplus 12/3000/120 45Hz, screenshots below
I have measured the frequency of my inverter utilising MK3 USB Bus and Victron connect. The frequency was 44.7 Hz via Victron Connect when operating as an inverter from the batteries with no Grid or Generator connection. I checked the circuit with a hertz meter (RS PRo frequency Meter) and this confirmed the low Hz reading.
Software adjustment within Victron connect, when I adjused this to 60Hz this had no affect and the frequency remained at 44.7Hz. You will se the Hz problem in the left screen.
Is there a physical adjustment on the Mutliplus or another way of resolving this issue.
Regardless of the load or voltage the frequency remains the same.
I do not have VRM
