I have two Cerbo GX.
I have used 2.70-3 large-12 for a while. It worked perfekt.
For a cupple of days ago I updaded both to 2.70-5 large-18.
Now I have one who runs perfect and one who not run so god.
On that one who doesn´t run, I cant reach Node-Red. (no server runing) I can reache Signal K.
Another problem is that almost all settings go back to default when I reboot.
The other one works perfect.
If I go back to 2.70-3 large-12 I can reach Node Red, but my settings is still reseting at reboot.
Setup on the "perfect" one:
Cerbo GX
Smartshunt
SmartSolar 75/15
Phoenix inverter 12/1200
SmartBatterySense Black
USB GPS
TempSensor for GXDevice Meassure the engine temp)
Setup "not so perfect"
Cerbo GX
BMV-712
MultiPlus 12/2000/80 230 (with it´s own temp sensor on battery)
VE.Bus smart dongle (with external temp sensor on battery)
VE.Can to NMEA 2000-adapter
Temp sensor for GX (measure the temperature inside the boat)
USB GPS
Any idea how to solve the problem?
//Palle
