felix-schlotter avatar image
felix-schlotter asked
manufacturing date of multiplus
Hello!
I received an used victron MultiPlus Compact 12/1600/70-16.
Unlike any other multiplus it is called phoenix compact multiplus. (it looks like that :https://www.google.com/search?q=victron+phoenix+MultiPlus+12/1600/70&client=ms-android-xiaomi-rev1&prmd=simvn&sxsrf=ALeKk03rx69gsTV2FRT68MiGzDa-nqqEcQ:1618206782098&source=lnms&tbm=isch&sa=X&ved=2ahUKEwj7zq2DgvjvAhXNg_0HHSh0BvwQ_AUoAnoECAIQAg&biw=393&bih=682#imgrc=INe30ZQh0cjT7M)
Does anyone know when this Model was built or when the Name was changed?
Thank you for your Help.
Best regards
Felix Schlotter
Your picture is not working.
On the back and/or inside of the unit should be a sicker with the serial number.
I guess this unit is at least 13-14 years old. The name switch from "Phoenix MultiPlus" to just "MultiPlus" was somewhere between 2007 and 2008.
