I have a MultiPlus Compact 12/1600/70 with a BMS CL12V 100A
Unfortunately the Multiplus has no AUX inputs but luckily Victron has a cable in his portfolio. “Cable for Smart BMS CL 12-100” to MultiPlus. Switch the cable the whole device on and off? Are the Output analog or digital?
How is the security regulated if the cable has an impact? Do I have to enter something for the cable in VE.Confiure?
Alternatively, I can also use the temperature port. Maybe it’s the better choose. With this Port I can control the charger, but not the inverter. I have the option to switch to float when the full charge level is accessed.
I think I can't do that with the special cable
What did you suggest
