Hi, I was going through the VE Mppt calculator excel sheet and going through the panel configuration options with my 100/20 mppt.
I am planning to oversize my current PV configuration (1x CSU-360P) by adding one more of the same model/brand so I can easily transition to 48v in the future. The calculator says that I should still work but gave a warning that it is more than 30%. May I know if exceeding 30% oversized negatively impacts the the mppt scc itself or what will happen if I exceed that threshold?
