I have a 3-phase system consiting out of 3 Mulitplus 2 GX 5kVA inverters, a Cerbo GX, Pylontech batteries and 3 MPPT's.
When Inverters supply non-essential loads on AC Input side, the one inverter (L1) frequently feed power to the grid although I have a similar 1.8kW load on all three phases (3-phase element). The second inverter (L2) also pushes a bit back, but not as bad as L1 and then L3 is perfect. The Grid-meter (EM24) seems OK as when I deplete the batteries and it supplies the same 3 phase from the grid then all is good.
I have set grid feed-in to 0, and minimum set-point to 150W. Any additional items I could check?
Thanks
I have tried to elaborate in another post, but seems I was just not descriptive enough and not found a solution.
