While testing @Louis van der Walt 's new BMS driver for the GX I noticed that the VRM Dashboard displays a different temperature value to the Advanced tab. All the source data are correct. Remote Console Temp, DBUS published value and the VRM Advanced tab. The only one not displaying correctly is the VRM Dashboard.
Any idea why the Dashboard and the Advanced Tab widget shows different values?
Edit: Here is the strange thing, as soon as I added the Temperature Widget in the Advanced Tab the Dashboard temperature changed from 21 degrees to the correct 27 degrees. That is strange indeed.
