I'd like to create a system with 2x Multiplus' (Compact 12/2000/80) with monitoring of each using a Cerbo GX.
This seems straight forward, but I need the inverter AC circuits completely isolated - this is done for redundancy alone. The inverters may be used separately but they will always charge the battery bank together. The shore power AC circuit & the DC input/output will be shared between the two units.
Is it possible to have 2x Multiplus units connected in a VE Bus string purely for inverter & shore power load measurements on the Cerbo GX & VRM?
