Symptoms:-
- Cerbo WiFI set-up says 'No WIFI adaptor connected.
- Cerbo Ethernet set-up says 'Unplugged'.
- Bluetooth not visible on iPhone.
Ethernet is connected, Cerbo RJ45 sockets lights normal and ethernet connection tested on laptop.
Cerbo can create WiFi hotspot; can connect with iPhone and use browser to view remote consul. It cannot however see WiFi hardware for a connection out.
Cannot get WiFi, LAN or Bluetooth to work. All have been working fine since purchasing Cerbo three weeks ago.
On the day this fault appeared, I did three things:-
(1) Install v2.7
(2) Switched on K-signal and created a few instruments on the v2.7. dashboard app.
(3) Connected MPPT75/15.
I do not know at which point in this that the faults appeared.
I have now reinstalled v2.6 and removed MPPT connection but fault remains.
Any ideas?
Many thanks.
