bretto avatar image
bretto asked
Easysolar power down via relay
Trying to provide battery protection for a diy lfp battery connected to 24/3000 Easysolar and wish to disconnect it from cells when issues arise around cell voltages. I have a battery protect on the dc loads for low voltage protection and have the charging parameters on solar charger and multi set for high voltage protection but nothing for individual cells.
I have found an individual cell monitor, microcontroller-based and uses two Solid State Relay (SSR) outputs to separately signal over-voltage or under-voltage conditions. Is this a means of switching off the Easysolar via the relay in the Easysolar? Any suggestions or additional info. Cheers, Bret
Easysolar 24/3000.
BP 220
Bmv 712
Digital remote
2p8s battery
BMS
bretto avatar image
bretto answered ·
I have heard that the multi can be switched off using the remote switch provision, however, I have installed a digital remote and only one of these can be utilized at any one time.
