I have a boat based system with 2x SmartSolar MPPT controllers charging 1400Ah of 24V MG Energy LFP batteries controlled by an MG BMS and a Victron CCGX.
One of the SmartSolars is connected to 2x custom 10kSolar RAIS 400W solar panels that have integrated MPPT controllers and that output a steady 55V with current varying according to illumination. 10kSolar is out of business now.
I very much like the full Victron / MG Energy integration and want to keep using the SmartSolars, but the problem is that their built in MPPT algorithm is incompatible with the panels.
The MPPT algorithm gradually drives the output voltage of the panels down to the point where the panels switch off and then restart about 10 seconds later. This happens at a panel voltage of about 29V.
The panel spec calls for output voltage to be managed in the range from 55V to 35V.
Is there any way to disable the SmartSolar MPPT function, reduce the range, or set it to a fixed value as in an MPPC controller?
Thank you for any help with this!
