Hi there.
Situation: Battery, MPPT Smart Solar and Multi are in the barn, CCGX ist in the living room.
VE.Direct max. Cable length is 10 meters. Distance I have to build is 20-25 meters.
Any ideas? Maybe convert VE.Direct Protocol to CAN? Or just use some BUS Amplifiers such as 7406? (I am an eduacated electronic technician with no fear for soldering irons :-)
Or convert VE.Direct to any other Protocol such as TCP/IP? Wireless/ BT is no good idea because of some thick walls.
Thank you very much for helping!
Greetings
Steve
to a for example CAT6 cable??
