Currently I have two 24vdc Battleborn batteries and at 240 watts (two 50 watt in parallel and one 100 watt panel in series with the two parallel panels).
I am considering the following:
1 each. Victron BlueSolar MPPT 75/10 for Solar to engine run battery maintenance.
1 each. Victron BlueSolar MPPT 75/15 for 24vdc system battery.
1 each. Victron Orion-Tr 12/24-5A DC-DC Converter for 12vdc to 24vdc ignition on charging for system battery while vehicle is running.
1 each C24/1600 inverter.
Question; would the the BMV-712 Battery Monitor work on a 24vdc system... recommendations?
