jgy67 avatar image
jgy67 asked
Use the ac2 output for a secondary battery charger
I´m considering a secondary 230v batteri charger in addition to my Multiplus 24/3000/16/230v.
I´m thinking of utilizing the AC2 230v output from the MP.
with regards to this, I have a few questoins:
- Is this a recommended setup?
- If so , would the Venus GX then reflect the real power consumption from the gen set?
- Is the entire power consumption limited to 16a 230v
Thanx.
Kind regards
Jan G
Paul B avatar image
Paul B answered ·
- Is this a recommended setup? yes AC2 out only has power when there is power on AC1 in
- If so , would the Venus GX then reflect the real power consumption from the gen set? YES
- Is the entire power consumption limited to 16a 230v as the pass through relay is limited to a max or 16 amps with your model of multi plus then 16 is the MAx power in total for any input from AC1 in
