yannd avatar image
yannd asked
Mppt100/50 with 2x320w solar panels
Good day, i have a MPPT 100/50 charge controller, can i hook up my 2 320watts panels in parralel giving me 640watts ? My batteries are 12 volts.Thanks !
MPPT Controllers
rickp avatar image
rickp answered ·
Because the solar panels, solar charge controller, and batteries work as a system, the specifications of all three determine the answer. Not knowing how many and what size batteries makes this a “maybe proposition.
Go to the Victron MPPT matcher app and plug in the info for your panels and batteries, and it’ll give a reliable suggestion for a charge controller. As long as it it equal or smaller than your 100|50, you’re good to go!
Select “custom module” to plug in your brand of panels’ data.
https://mppt.victronenergy.com/
yannd avatar image
yannd answered ·
Thank you for your link, i have 2x12 volts x150amp batteries in parallel (300amp total) with a 280w 24volts panel on my mppt 100-50, i was just wondering if it would be too much to replace my current panel with 2x320watts. System runs great fom april to mid october but later in the season i have to use my generator to charge my batteries...Thanks !
