jacksonhallett avatar image
jacksonhallett asked
Connections multiplus replace Trace
I replaced my old Trace Inc/ charger with the Victron multipluss12/3000. The Trace has a green terminal block with battery size cable going to ground bus block on the boat. Not sure where to attach it on the multiplus- other - neg bolt next to meg battery cable or to frame nut?
swampbush avatar image
swampbush answered ·
Sounds like the earth wire. It should go on the earth on the multiplus.
