- I have a Victron 75/15 a 100w solar panel and two Varta Ldf90 batteries.
Today, I noticed the solar controller was showing 0 watts being generated although it was sunny. On further checking, there has been no charge going into the batteries for 2 days. This morning, I received a firmware update for my 75/15 which installed correctly. Immediately afterwards, the controller showed 20w being generated which quickly dropped to zero even though it was sunny.
I checked the battery settings in the app and changed the battery preset to default. The controller then showed power being generated by the panel. When I changed back to user defined preset,( Varta LFD90) the controller again showed 0 watts.
Any ideas why the presets suddenly don’t work?
The controller operation mode is set to Batterylife.
