I have noticed that while there is a screen which correctly reflects the Charge Disconnect or Load Disconnect status of the MultiPlus (irrespective of assistant used - 2-Wire or VE-Bus).
When the state changes, no alarms are triggered on the Venus OS, and nothing is logged in the VRM Portal, either as an alarm or as data field.
Would it be possible to trigger an alarm on the VenusOS, and report that through to VRM. Maybe also making use of the statue of the BMS available through these two "System Overview" values in VRM
#3 Charge disabled by BMS
#4 Discharge disabled by BMS
This would allow those users of a VE.Bus BMS or smallBMS to get an alert that there is an issue and have it logged. At the moment, those of us remote from the batteries are unable to get any alarms of an issue.
I have thought about wiring the CD and LD into digital inputs, whitening a revision to the Digital inputs driver to label them as BMS events and capture logs through the alarms available. It just seems like a waste of Digital inputs when the data is already available.
Many Thanks.
