From previous threads, I've seen how I can set my Multiplus Compact's charging for CC/CV charging of my LiFePO4 drop-in batteries. That approach (setting Max Amp to the batteries charging specs, setting equalization to the shortest time, then setting the float voltage to the level at which you wish the charging to kick back in again.
As a side note, it seems strange that selecting the lithium battery mode in the charger doesn't seem to change the menus to offer the types of charging parameters one uses for lithium batteries.
My understanding is that for long storage periods (say a month or more) it is best to leave the lithium batteries at about half charge. Can I accomplish this by setting the Multiplus with bulk charging voltage of that of a half-charged battery, minimum equalization time, and a float voltage that is also the half-charge voltage? Will the charger then keep the battery in that mid-charge range?
Is there a better approach to this?
Basically, our boat tends to be either used for long cruises with the energy system heavily used, or sitting at dock for long periods of time. Not much "day sailing" activity. Since this would seem a fairly common situation, it would be nice to be able to easily switch back and forth between "use" and "store".
Any ideas for a good way to address this are much appreciated.
