I have a Smartsolar mppt 75/15 with Liontron LifeP04 battery 150ah.
Does a choice on the Connect app for lithium meet the following battery data or are more specific settings required?
Nominal capacity 150Ah / 1920Wh
Working voltage range 11.0 .. 14.6 V
Charging characteristics CCCV / IU
End-of-charge voltage 14.4 - 14.6V
Trickle charge 13.5 - 13.8V
Recommended max. Charging current 75A
Max. Charging current 150A
Duration discharge current 150A
Max. Discharge current (≤ 20 sec.) 200A
Integrated BMS battery management system
