I assume using a zappie charger 7k would overload a multiplus II 48 volt and if wired for full ess where all grid power goes through the inverter and could damage the inverter or does the inverter switch through to provide the excess from the grid above the capeability of the inverter or would it be necessary to wire the inverter as a parralell system
