Hello Guys,
i have customer reporting a failure of the victron phoenix inverter 12/1200 (the old one,none ve-direct), he cannot draw any power.
for now, i only have the flash sequence, however, i could not find this sequence in the table in the manual. also the bmv says: the battery is still at 70%.
the most important information for me is missing at the moment: i dont know the battery voltage at the time of failure. i would update it as soon as i get the info.
can any body help me to find the meaning of this flash sequence/ failure code:
green: blinking fast/ 2 times per second
red: blinking slow / 1 time per second
couldnt find any similar topic. thank you for your help in advance
sunny greetings, Ferdi
