Hi
Does anyone know if I can connect 4 x SmartSolars to the CERBO via BT?
Or is there an alternative multi BT to WiFi adapter/transmitter to my "home" network?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
If you look at the manual, the Bluetooth is designed for monitoring and communicating via Victron Connect with your tablet/smart phone, https://www.victronenergy.com/media/pg/Cerbo_GX/en/accessing-the-gx-device.html
The mppts connect via VE Direct cables, https://www.victronenergy.com/media/pg/Cerbo_GX/en/installation.html
Thanks for your reply @Alexandra
How to connect 4 x VE.Direct cables to the Cerbo GX i understand there is only 3 inputs
You will need to use a ve.direct to USB adapter for the fourth mppt
For more than 3 MPPTs, it is recommended to use the VE.Can models, they allow daisy chain of up to 25 MPPTs.
23 People are following this question.
