Manda avatar image
Manda asked
ESS can't be used in my country ?
Hi. I'm living in Madagascar. I have a 5kVA Multiplus, a cerbo, 2*150/35 MPPTs, 2790 Wc PV array and I wait to be delivered lithium batteries.
There is "nothing" about feed-in here, so let's say that it is prohibited. No way to get the grid code standart and "password" required in ESS setting.
I read that "If you leave this setting as 'None', the system will not supply battery energy to support local AC loads when the grid is connected. You do need to change this setting even if it is your intention not to export DC energy to the grid." That's why my question : Can't I use ESS (any of the 3 modes) ? Is there any alternative for my need ?
I want to use the grid power only when power of PV is not sufficent to power load and SOC less than a specified value.
Thanks
ESS
sparkpoint-solar avatar image
sparkpoint-solar answered ·
Don't use ESS, use the virtual switch.
Manda avatar image
Manda answered ·
Thanks for the answer. In fact, after reading further, my wish sounds like what they call "inverter priority": NO ESS.
I'll read more about virtual switches.
If your grid is corect, you can use the ESS with grid code other and ad an anti islanding system like the zielh
with ESS it s more easy !
Manda avatar image
Manda answered ·
"Thierry Cortassa (Victron Energy Staff) répondu · il y a 12 heures
with ESS it s more easy !"
Indeed, ESS sounds to be "the" solution, but the grid is very bad in my country (the poorest I ever see : off for 2-3 hours 1-3 times a day, 125-210 V 70% of daytime) that's why the purpose of solar energy installation.
I thought that entering any grid code standart requires a password (even the international ones)… I'll double-check
If you talked about the UFR1001E, the purchase from Madagascar is difficult (the cost, payment and shipping)…
I'm trying to make an utility (node red - mqtt - raspberry pi) to handle the parts of my install and to record some data, so, perhaps, a possibility to hand-make an anti-islanding system… but once again, I don't know about legality
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
