Having installed and tested a MPPT 100/30 into a LifePo4 200amp Victron battery. Mppt and bmv were showing the same battery voltage.
Today the MPPT is showing it it hits float voltage of 13.5 but BMS CL 12-100 and BMV show 13.14v. As a reault the MPPT is changing to float. So I changed settings to float 14.2 to see if it changes back to bulk
On doing the MPPT immediately changed the battery voltage from 13.5 to 14.2v. Attached are Screen shots. Firmware is up to date v 1.50
Is there away to re-install software. Reset factory defaults then changed settings but didn’t change problem
