mariopuzo avatar image
mariopuzo asked
Quattro 48/10000 buzzing
Hi All,
I have recently upgraded from a Quattro 5000 with %kwh Freedom Won battery to a Quattro 10000 with 15KWh Freedom lithium battery.
Problem is the 10000 on normal running with minimal load of 100watts is making a buzz constantly. Is this normal? the 5000 never used to make this noise unless under load.Please help.
Mario
Paul B avatar image
Paul B answered ·
Hi Mario, thats a bit of a open question,
I presume the quattro is second hand .
Much more Info would be required to give a fully correct answer.
How load is the BUZZING
is it a relay buzzing buzzing noise
is it a Transformer buzzing noise
Maybe its in AES mode
A recording of the noise and some screen shots of all the settings. if you have a CCXG or venus unit then some screen shots of that as well.
As much information as you can send
