In an ESS installation (with a CCGX), what does "maximum inverter power" /"limit inverter power" represents here? Is it the AC power delivered to the loads on ACout2 of the multiplus?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
If I'm not mistaking: the maximum power the unit will generate from the batteries, it doesn't matter if it goes to the input or the output.
if more power is used, this will come from the grid.
(does anyone know if the maximum grid current setting of the multi is still maintained with this setting enabled?)
Also: when grid failes, this setting doesn't work, inverter will try to supply loads to it's maximum power.
See the documentation:
https://www.victronenergy.com/live/ess:design-installation-manual
Chapter 4.3.10.
4 People are following this question.
