I have been asked by engineering company if it is possible for current to flow from batteries through the solar charge controller (Smart Solar MPPT 150|85) in the case of a fault within the solar panels or cabling.
The system will have circuit breakers on the batteries and on the incoming solar input. I guess they are being over cautious as to the correct cable sizing.
I would have thought that there would have to be a fault with the charge controller for this to occur, as at night there isn't any current
any input would be appreciated
