jose-rueda avatar image
jose-rueda asked
What is the Mean Time Between Failure (MTBF) for the Quattro
Need info about MTBF for Quattro 48/3000/35-50/50 120V
Thanks
pracman avatar image
pracman answered ·
Looking at quattro specs say sub 20ms assuming you mean change over on power failure on one supply. https://www.victronenergy.com/upload/documents/Datasheet-Quattro-3kVA-15kVA-EN.pdf
If your referring to the life of the unit itself the warranty period is a guide.
