J P avatar image
J P asked
Right inverter for a 30A travel trailer
Can someone recommend the right inverter (3000w) for my 30A TT? Was thinking the MultiPlus 3000 but does it work with a 30A system?
Phoenix Inverter
Jeremy Albrecht avatar image
Jeremy Albrecht answered ·
The Multiplus 3000 will work great for your 30a trailer. Since your trailer is designed for a single 120v circuit the wiring will be much less complicated than it is for a 50a dual 120v trailer. You’ll need to set the input current limit to 30a to prevent drawing too much power through your cable though.
