martin-haellsten avatar image
martin-haellsten asked
Self consumption Smartsolar 75/15
I measured the self consumption of my smartsolar 75/15 to be 0.11 A (110mA) using my BMV 712 (everything else disconnected) and toggling the unit on and off. That is more than 11x compared to the specificiation. It seems to be flawed. Or are the specs wrong?
MPPT SmartSolar
dazey77 avatar image
dazey77 answered ·
The BMV isn't really intended for measuring such small currents. I think the issue is that you are within the accuracy tollerances. If you want to measure the consumption, put a sensitive multimeter in series with the BMV connection.
The smallest current the BMV can show you is 0,1A and even that is more a guess than a accurate measurement.
As @dazey77 wrote, you will need a way more accurate measuring device to measure such small currents.
