I have an EasySolar 48V 5000VA, installed 30 days ago. It fans, from day one, are extremely noisy. With an uncalibrated phone based noise meter, the EasySolar sound measurements are:
1 - OFF / Silence - 20dB
2 - At my workspace - 50dB (EasySolar fans at full speed)
( 5 meters from
the Easysolar)
3 - 1m from blue encl. - 60dB (fans at full speed)
from the EasySolar)
4 - Outside the encl. - 80dB (fans at full speed)
(5cm from hot air outlet)
The current fan JF1238B2HR-R, gives a spec of 43.5dB, which means the position of fans in the blue enclosure is the reason for the noise.
I have not yet opened the enclosure to understand why it makes such a noise. It is not bearing noise, just the fan air noise.
Replacement Fan: I need some advice - I read here than some has replaced the fans with the a Noctua equivalent, which has much as lower noise spec? Was it worth the effort?
I guess replacing these fans myself will affect the warranty?
My alternative is the cost and effort to have the EasySolar moved to another room, with the lengthening of the wires.
Sound meter measurements
