nixonlm1950 avatar image
nixonlm1950 asked
100/50 has volts, but no watts or amps
It was suggested that I post this as a new thread.
I have four roof panels connected to a 100/50 controller and two ground deploy panels with its own 100/30 controller. The settings on both controllers are identical. When I last used the roof and ground deploy panels everything worked fine. Now this issue has popped up:
The groun d deploy panels are working fine (100/30), but the roof panels (100/50) shows volts and no amps or watts.
I’ve unplugged the roof panels and the voltage drops to zero as expected. I disconnected the 100/50 controller from the panels and the battery, disabled the 100/30 charger in the app, and reinstalled the 100/50 per the directions. It didn’t solve the issue with the 100/50 showing voltage and no amps.
Since the controller can see both the panels and the battery I don’t believe it’s a curcuit breaker. I also don’t believe there’s one in my installation.
MPPT Controllers
solarone avatar image
solarone answered ·
I had a similar problem with a 100/30 (see link below )
It turned it to be fuse inside the unit that had blown
My unit Was out of warranty so I replaced the fuse it not easy though
https://community.victronenergy.com/answers/4902/view.html
nixonlm1950 answered ·
I didn’t know the controller had built in fuse. I’ll see what I can find on replacing it. I ordered a new one on Sunday just in case. I live full time in my RV so solar is important.
solarone answered ·
Depending on how old the unit is you may be able to contact the supplier about warranty .
The fuse is soldered to the circuit board and It’s like a very small little fuse but here in au/nz I couldn’t find any like it to fit it so put a fuse holder on it
Au/nz don’t have the of large range of dealers and product spare parts Like the rest of the world
It was a bad controller. I installed a new one and everything’s fine. I don’t have time to wait for a warrenty repair.
