dave-and-becky-waterman avatar image
dave-and-becky-waterman asked
State of Charge Low
Hi Community,
After a bit of help here. My collegue has a setup with a MultiPlus Compact 24/2000/50-30, a BlueSolar Charger MPPT 100/50 and two 250 watt panels. This is then with 8 Hopekeca 6 Volt, 550AH AGM batteries. We recently added in the raspberry Pi3 as a venus device with the ESS assistant running on the multiplus.
It appears to all be working fine, its does a scheduled charge at 6pm local time but never chargers to higher then 93%. I'm expecting I have got a setting wrong somewhere in the multiplus, but I'm not 100% sure.
In the multiplus it is configured for Gel/AGM batteries and for 550AH, but we still get a low reading from the state of charge.
I have a very similar setup of the EasySolar system and the same batteries which is showing correctly and as far as I recall I configured then Multiplusses the same.
Any advice greatly received.
You seem to have a discrepancy regarding inverter voltage (24) /battery count (8 x 6v) /battery Ah (550Ah) .
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Seen same before on a MPII.
Although the MP can calculate the SOC, it is a best guess. Getting a BMV will give a much more accurate SOC.
