I'm looking for the best way to charge 10 x Victron 12.8V/90Ah Smart Lithium batteries. The batteries will be used every day in 10 different mobile devices and then brought back in the evenings to be charged over night.
Should I go with 10 dedicated chargers and 10 miniBMS for each battery or use something like a Skylla IP44 with 3 outputs and charge the batteries in parallel (Output 1 x 3, Output 2 x 3, Output 3 x4), I could then use a VE.Bus BMS to shut the Skylla down in case of overvoltage, but then all 10 batteries would stop charging if there was a problem with only 1 of the batteries?
The miniBMS option might be a better option as the miniBMS could travel with the battery and a Cyrix Load relay to protect from under voltage during discharge each day.
Just looking for any ideas on the best way to go about this? Thanks for any thoughts or ideas.
